OK, so I know my way around air cooling quite well, however my processor is sitting a bit hot (60-63 on load) and that isn't ideal.
So what I need is a bit of advice on what pump, rad and block to get to cool a QX9770 at 4.0GHz and possibly the northbridge.
Will a 240mm rad do, if I went for a Black Ice GT type thing, with a pair of 88cfm fans on?
How much heat can they dissipate and what pump should I get to go with it?
What is the best 775 block?
Also, I move my case a lot, normally lying on its side (not upright), will the whole thing need draining and leak testing each time, in which case its probably not worth doing water cooling.
