wrenaudrey
Member
I've previously made a thread before about going with a fully pledged water cooled system or get a H100i, but that's old and dead now.
But in the end, I've decided to go with a fully pledge WC system,...in the coming months (because im not a millionaire...yet).
So...what is the 'just the right amount of rad'?
I have a CM Storm Stryker (just recently bought).
These are the ones im willing to 'get wet', when they are released(some):
i7 4770k - low/mild OC, 4.2-4.6GHz
Z87 Motherboard - not super high end nor too low end
Asus GTX 670 DCUII - maybe a 2nd in the future
Now the rads. Yes I know, the guv'nor has a vid on modding this case for a 360 up top but I don't really have the tools or the 'modding hands' that some people have got nor am I willing to sacrifice that handle; because dayum! this case is he-a-vy!
Ok now seriously, the rads. I was thinking of 2x 240mm.
To be precise,
1x Alphacool ST30 240mm for the top http://specialtech.co.uk/spshop/cus...0mm-Dual-Radiator--Full-Copper-pid-15304.html
1x Alphacool ST45 240mm for the bottom http://specialtech.co.uk/spshop/cus...0mm-Dual-Radiator--Full-Copper-pid-15353.html
OR
2x XSPC EX 240mm for the top and bottom http://specialtech.co.uk/spshop/customer/XSPC-EX-Series-240mm-Dual-Radiator--EX240-pid-14705.html
Will 2x 240mm be enough to cool the components stated above?
____________________________________________________________________________
Major change at post #5
To be precise,
OR
Alright okay, first of all I thought about it very hard and have decided to return my Storm Stryker.
And I have now bought and have right beside me a white NZXT Switch 810
I've got my ruler out and measured the rad places that is ideal.
So here is what I've come up with:
Top: 1x Alphacool XT45 360mm http://specialtech.co.uk/spshop/customer/Alphacool-NexXxos-XT45-360mm-Triple-Radiator--Full-Copper-pid-15354.html
Bottom: 1x Alphacool UT60 240mm http://specialtech.co.uk/spshop/customer/Alphacool-NexXxoS-UT60-Full-Copper-240mm-Dual-Radiator-pid-14818.html
OR
Top: 1x XSPC EX360 http://specialtech.co.uk/spshop/customer/XSPC-EX-Series-360mm-Triple-Radiator--EX360-pid-14706.html
Bottom: 1x XSPC RX240 http://specialtech.co.uk/spshop/customer/XSPC-RX-Series-240mm-Dual-Radiator--RX240-pid-7874.html
Now will that cool, with reasonably low rpm SP fans, 4770k @4.2-4.6Ghz and a potential 2x Asus 670 DCUII?
Edit: Planning only a PULL config, for starters on both rads.
