Sniper Elite V2 Benchmark
Kaapstad
Active member
I have been having a bit of fun with this using the settings below
Single 290X @1260/1625
4930k @4.7
Sniper Elite V2 Benchmark Report
Created: 2014-02-24 at 19:24:36
Build Version: 1.13, Apr 11 2013
Average FPS: 57.8
Minimum FPS: 30.3
Maximum FPS: 253.9
Number Of Frames: 4428
Average Frame: 17.310ms
Minimum Frame: 3.939ms
Maximum Frame: 33.001ms
Machine Name: HAL5
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
GPU Name: AMD Radeon R9 200 Series
Feature Level: DX11.0
Driver version: 8.17.10.1247
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
4x 290Xs @1240/1500
4930k @4.7
Created: 2014-02-24 at 10:59:25
Average FPS: 210.5
Minimum FPS: 18.8
Maximum FPS: 1147.7
Number Of Frames: 16076
Average Frame: 4.751ms
Minimum Frame: 0.871ms
Maximum Frame: 53.328ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Just downloaded the standalone file. How do you change the setting like you have, presume yours is in game?
Edit: add my result (can't change any settings)
Created: 2014-02-24 at 22:01:15
Build Version: 1.05, Jun 7 2012
Average FPS: 77.2
Minimum FPS: 7.0
Maximum FPS: 510.8
Number Of Frames: 5906
Average Frame: 12.951ms
Minimum Frame: 1.958ms
Maximum Frame: 142.979ms
Machine Name: BLACK
Monitors: 1
Operating System: Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8175MB
CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 670
Driver version: 9.18.13.3489
Resolution Width: 2560
Resolution Height: 1600
Anti-aliasing: HIGH
Advanced Shadows: LOW
Supersampling: 2.25x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Stock GPU 1000\1300 & OC CPU 4.00Ghz
Created: 2014-02-25 at 01:51:16
Average FPS: 40.2
Minimum FPS: 22.7
Maximum FPS: 83.3
Number Of Frames: 3074
Average Frame: 24.901ms
Minimum Frame: 12.005ms
Maximum Frame: 44.039ms
Machine Name: SIEB
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 8149MB
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Number of Cores: 4
Driver version: 8.17.10.1267
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
OC GPU 1230\1550 & OC CPU 4.00Ghz
Created: 2014-02-25 at 01:55:10
Average FPS: 45.9
Minimum FPS: 22.0
Maximum FPS: 125.7
Number Of Frames: 3520
Average Frame: 21.775ms
Minimum Frame: 7.958ms
Maximum Frame: 45.423ms
Machine Name: SIEB
Monitors: 1
System RAM: 8149MB
Number of Cores: 4
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Not much of a benchmark but...
FX 8320 @4ghz HD7950 @ 1100mhz/1500mhz
Created: 2014-02-25 at 03:13:37
Average FPS: 32.0
Minimum FPS: 15.9
Maximum FPS: 184.1
Number Of Frames: 2448
Average Frame: 31.255ms
Minimum Frame: 5.432ms
Maximum Frame: 63.026ms
Machine Name: COOP-PC
Monitors: 1
System RAM: 8108MB
CPU: AMD FX(tm)-8320 Eight-Core Processor
Number of Cores: 8
GPU Name: AMD Radeon HD 7900 Series
Dedicated VRAM: 3054MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
