slow leak, pump res or compression fitting?
Asus11
I just put together my WC Setup, after taking it apart when I sold my titan, well I have another so it was time to put it back together, but what I noticed when the WC setup was out
the first time some very small coolant around the compression fitting where it connects to the res, I was glad I had sold the titan as it made me aware of this issue, I had initally thought
it was maybe not tightened properly so, fast forward a month I now have another titan, refit everything made sure everything was tight yet im loosing coolant way too fast and noticed the was small
leak from the same location!, what do you guys think it is? compression fitting/rubber ring(they look in good condition) or is it the res thread, and has anyone experience something like this before?
here is a picture of the location its leaking from highlighted in red ( this is an older picture when I was using distilled(now using red Mayhems coolant) but uploading it just for reference on the location )
Check your o-ring on the fitting where the leak is; it might not be seated properly. Otherwise safer to replace that whole fitting.
