Sli Support
equilibrium
Due to problems on my msi diamond board where the graphics cards sagged ive come up with a simple solution,,
http://img472.imageshack.us/my.php?image=slisupport8vb.jpg
Not sure if something similar has been done already but id thought id put my ideas here for anyone needing ideas.
All needed is a threaded bolt long enough to go through the bottom of the case and nuts and washers. Basically Nut under the case and one on the inner bottom to hold it in place. Then tighten a nut under each gpu to support it to the correct height needed and one on top of each if needed. Can always spray the nuts and bolts to match case if needed :) This is only an idea so id thought id share it.
Dave
LOL@ daguv i love it its pure genius!!! Thanks aswell i thought the bolt could be merged in to make it go with the case but i have seen another way of doing it and if i find it ill post it up.
Ok i cant remember where i saw it but it was basicallly one of these without the light holding up the card! It looked very good i have to admit.
