Because you can mark out your cut on tape. Also even though its incredible minimal, you are less likely to "slip" on the initial cut/mark with tape (when a novice user)
I'm definitely not a beginner in pc modding , but I like to have a clearly printed line on which I will sew, besides that the tape serves to protect the rest of the acrylic from the possible damaging and bundling of cut-off parcels.
Project is finished, on this occasion, I would like to BIG thanks ASRock, Teamgroup, Cooler Master and AMD company for helping with this project.
Hardware:
MB - ASRock Phantom Gaming 6 x399
GPU - ASRock Phantom Gaming RX590
CPU - AMD Ryzen TR
RAM - Temagroup Xcalibur Phantom Gaming
SSD - Teamgroup Delta RGB Phantom Gaming
CASE - Cooler Master H500M Phantom Gaming
PSU - Cooler Master V850 Platinum
COOLER - CM ML360 AIO TR cooler
Thanks for watching us work, stay tuned!
