Should i get the sapphire r9 290
PC Master Race
OK so I want this card it fits my build and looks cool and performs well.
But I was wondering if I should get a different gpu or choose a different brand.
I am a new pc master race brother so I don't know everything about pcs and graphics cards.
Any help would be a huge help.
I am willing to spend anything under £280:)
Depends, do you game on 1920x1080 or 2560x1440 resolution? The R9 290 is perfect for 1440p gaming with decent fps. A bit overkill for 1080p.. For just 1080p, the R9 280x should be decent enough and saves you some money.
But tbh, I use the R9 290 with 2x 1080p screens at the moment, I might buy a 27'' 2560x1440 screen later this year.. It's because the game I play mostly (Starcraft 2), doesn't support 1440p native because it apparently could give you an advantage compared to other online players.. I thought a 1080p game on a 27'' 2560x1440 screen would look odd, so I bought a second 1080p Dell instead. I just wanted the second fastest card available (best bang for buck), and the card which was relatively future proof, so that's why I went for it (sold my old HD 7870 for 100 euros, so at the end only spend 250 euros for the 290) ^_^
But anyways, can't complain much about the card. The Tri-X and Vapor-X are both very good options! If the colors fit your build, go for it!
ty for detailed and helpful answer
The 290 is still the best bang for buck when it comes to getting a high end GPU. The Sapphire vapor x is one of the best coolers available for the R9 290 series as well, with only the PCS+, Tri-X, and MSI Lightning cooler rivaling it.
I'd go for it. For 1080p gaming it still makes sense as to really have a smooth experience, you don't want it dipping below 60fps, so having 80-100fps averages across the board is awesome. :)
