I'm considering moving over to a full custom loop cooling my CPU, Motherboard and Graphics Card. My current setup is:
6700K at stock speeds (Corsair H115i with 2x Corsair 140mm ML140 Pro fans)
Asus Maximus Formula VIII
Asus GTX Strix 1070 (stock cooler)
CPU Temp idles around 28c and never really over 44c under load, I believe once when rendering 4K video it hit 50c.
My 1070 is usually at 34c idle and 55c under load.
I would like to stick to EK blocks and 2x 280mm radiators, one in the top and one in the front both would have 2x Corsair ML140 Pro fans. I'm using a Phanteks Enthoo Evolv case.
Please could I get some advice...
Would it make a drastic difference to my temps?
Which blocks would you recommend?
I would need a slimmer 280mm radiator for the top as the H115i just fits but the front one could be a decent depth.
Is there a decent AIO solution out at the minute for the 1070 Strix that has a 140mm or 280mm radiator?
Thanks for any help
Thanks for any help
