Korreborg
Member
Hello again
Well my old buildlog "mITX Watercooled (280mm+240mm rad)" is not suiting anymore, as i won the battle
(i managed to build the dream PC, and it looked awesome), but i lost the war
(Not fulfilling the goal of a silent mITX machine).
If you are interested in the old build, take a look here: https://forum.overclock3d.net/showthread.php?t=81299
I eventually put shifted to a small ATX case, Fractal Meshify C, but having a windowed ATX case with a mITX board have irritated me since it was finished.
So what to do? Looked at 2700x vs 8700k, but was constantly looking at used PC's on a danish forum. And found a i9 7900x, ASRock X299E-ITX and 32GB 2400MHz i swapped with my ITX parts.
I searched on for a ATX board, and luckily i the forum sold their test sample of the Asus ROG Strix X299-E Gaming for 50% of the new cost. Giant WIN
Then picked up a 400mm Phobya rad with 180mm fans to mount external under the desk. 2 EK quick disconnects, and a monoblock for the board.
Still needed RAM, so picked up 16GB of Corsair Vengeance LPX 3733MHz C17 QC. I'm still not 100% sure i'm keeping the i9, so i need low profile ram, as the Meshify has the normal fractal height restriction when you add a 240mm radiator in the top. And lastly i picked up a new Samsung 970 EVO M.2 500GB, as the watercooling is going to block access to the primary M.2 slot =00=
So the parts
Fractal Design Meshify C TG (reused)
Intel i9-7900X Delidded with LM @stock (New, but used)
Corsair Vengeance LPX 3733MHz C17 16GB QC
EVGA 1080ti FE with LM @2025MHz
Samsung 850 EVO 250GB x2 in RAID 0
Crucial MX100 512GB (storage and light games)
Corsair AX860i with Corsair sleeved cables
Cooling
EK Monoblock
EK 1080ti block
Watercool Heatkiller glass res
Aquacomputer D5
Aquacomputer Aquaero 6 LT
EK CE280mm/45mm
EK SE240mm/28mm
Phobya Xtreme 400mm/36mm
Phobya G-Silent 18 700rpm
Corsair ML 120 and 140 on the EK rads.
A blend of EK and Bitspower fittings.
EK Duraclear 10/13 sift tubing
And finally Mayhem X1 UV Green fluid
RGB
Cablemod RGB/UV led strip x2 with one controller.
RGB on the MB and EK Monoblock
I have probably missed something. But what the heck
I'll get going, the steam backup has just finished
So the parts
Cooling
EK Monoblock
EK 1080ti block
Aquacomputer D5
EK CE280mm/45mm
EK SE240mm/28mm
RGB
