tolagarf
Member
I'm having a bit of an issue keeping my GTX 1080 below 60C at load in games and Valley benchmark with my combined Alphacool Eisbaer 360 and Eiswolf, so I want to add another 240mm radiator which I have in spare, but I'm really unsure if this would even lower the GPU temps at all? my fan RPM at load are around 1000'ish RPM.
It's odd because the first Eiswolf I had (had a bad pump, got refunded), which was a standalone version with the 120mm radiator attached to it, maxed out at 52C in Valley with a fan RPM of 600. I can't really decide if there's something wrong with the second Eiswolf, or this is a result of the combined loop with the Eisbaer adding to the temperatures in overall, even though a 360mm radiator should be enough. But I digress, I'm not really an expert in this area
I've been testing my setup in Valley with 100% fan speed and 100% dual pump speed. Pump speed seems not to matter between 50-100%, there is no difference in temps. 100% fan speed (2000 RPM) lowers the GPU temps to 51. Any thoughts on this, or am I wasting my time trying to fix this loop?
Full specs:
Phanteks Enthoo Luxe TG
i7 5930K @ 4.0 GHz 1.025v
GTX 1080 Founder's Edition
ASUS X99-E motherboard
Corsair Vengeance LPX DDR4 2400 MHz CL14 RAM
EVGA Supernova P2 750 watt PSU
Corsair ML120 Pro White PWM x 4 fans
Corsair ML140 Pro White PWM fan
Noctua NF-A14 iPPC 2000 PWM x 2 fans
Alphacool Eisbaer 360 CPU cooler
Alphacool Eiswolf GPX Pro GTX 1070/80 M01 GPU cooler
Full specs:
