Shiinsuh
I not long ago to my new case. Allthougth its not quite finished yet, I still have to braide a few more cables (specialtech ran out of the 2.5mm white dence braid so i got the last of what they had for now), I have to get another dyebomb for the dye too the purple is not strong enoygh at all. The promochill purple dye seems to fade badly after a couple of weeks. I may have to ditch it and go for some other coolant.
As for the case its self, I have a plan to have purple acrylic trim where the mest is along the side and have LEDs lighting it up and the DVD and res painted white.
Rig Specs
My System:
OS: Windows 7 Ultimate 64bit
CPU: AMD PhenomII X4 965-C3 ~3.4ghz
MB: MSI 990FXA-GD80
Ram: 4x4gb 16gb G.Skill 1600mhz Sniper
GPU: ATI Sapphier 6970 2gb
Sound: Razer Barracuda AC-1 dedicated sound card for headphones.
PSU: OCZ ModXstream 600w
HDD 1: 2x 500gb SATA Seagate 7200.12 (STRIP RAID)
HDD 2: 1x 500gb SATA Seagate 7200.11
HDD 3: 1x1tb Hittachi Deskstar
Optical: Generic samsung DVD R/W
Other: MSi USB3/SATA6 PCI-E 4x Card
Cooling:
CPU Block: Watercool HK CPU Rev.3 LT
PWM Block: Anfi-tec PWM 044 MSI 990FX-GD65
NB Block: Watercool HEATKILLER® SB Rev3.0 LT
Pump: Laing D5 Variable (Modded to take 1/4 BSP thread)
Radiator: EK-CoolStream RAD XT240
Radiator Fans: 2x Enermax Everest UCEV12
Case Fans 1: BitFenix Spectre 120mm
Case Fans 2: BitFenix Spectre 230mm
Resevoir: XSPC D5 Dual Bay Reservoir
Case: BitFenix Shinobi XL Full Tower Case White w. Window
Coolent: Primochill PC Pure Performance Clear
Coolent Dye: Primochill UV Purple
Tubing: Faser 3/8" Black
Connections: 3/8" Black Nickle
Case bits and bobs:
Lighting: Generic natural white 300smd LED strip
Cables: own made cables with specialtech 2.5mm dence braid white, and specialtech 2.5mm dence braid purple. Generic black connectors + gold plated pins.
Radiator fan LEDs changed to white
Rig Specs
My System:
MB: MSI 990FXA-GD80
Cooling:
Case bits and bobs:
