DudeAbides
Hi- Is it possible that the temp sensor on one of my cores is defective? I'm currently running at 2.7 with 1.42 voltage, and the heat difference between the two is just stupid. The cold core runs 26/41 idle/load, and the hot one runs 36/75(!) idle/load (all temps in c). I'm using Core Temp to measure temps and Orthos to load both cores. Which reminds me- the temp jumps from ~40 to 75 on the hot core almost instantly after I start Orthos. I've tried lapping my heatsink and even removing the IHS, but it didn't help. (It did drop overall temps, but didn't help even the difference between the cores.)
Is it possible for two cores in the same processor to run with a 30c difference between them? Wouldn't the one core bust when it got up that high? Or is it more likely that the temp sensor on the second core is just wrong?
Thanks for the help!
