Screw length
Jacob.xray
was just wondering what size screws (length) would you use to go through fans (25mm) the mesh on the case and the radiator
The screws that come with most radiators are 30mm and this should be fine for attaching fans to the rad through the case. These are always the size that I have used and they have been fine. Hope this helps.
