AverageNinja
Average Penis Too
I'd indeed drop the RAM to 8GB (leaves money for an upgrade, like a bigger SSD) and get a different case. An mATX board is going to look very small in the 540 air I think. The Arc Mini R2 is quite a neat case indeed!
I would change the 4670k for either a Xeon 1230 v3 or regular 4560 (as said before, he probably isnt overclocking if you are speccing the build), which also makes the h100i overkill, a cheap air cooler would do the job. The Phanteks TC-12DX is good, cheap and quiet and looks good through the window.
Hi
If your only planning on a single video card why not look at mITX motherboards and cases. The 540 air is a lovely case but will be quite empty with what you are planing to put into it. I have been very happy with the Corsair Obsidian 250D case and the H100i is perfect fit.
--Rick--
I think on a budget he will struggle to find an ITX board and case, they are generally a lot more expensive even for the cheapest cases and boards.
I agree on everything but the last part. An aircooler never looks good.
Here's a 1,000 pound list of the most beautifully matched components in a Corsair 350D
http://uk.pcpartpicker.com/user/John15293/saved/4qoZ
Intel Core i5-4670K 3.4GHz Quad-Core £164.39
Cooler Corsair H75 54.0 CFM Liquid £59.83
Asus GRYPHON Z87 Micro ATX LGA1150 £109.04
Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 £128.51
Samsung 840 EVO 250GB 2.5" SSD £99.90
Seagate Barracuda 2TB 3.5" 7200RPM £53.99
EVGA GeForce GTX 770 2GB £254.98
Corsair 350D Window MicroATX Mid Tower £84.96
Corsair 550W ATX12V / EPS12V £78.98
TOTAL - £1034
Theme is all black and gold and everything matches
This.4670k unnecessary, a 4670 will suffice for a person who lets other people build their rig. 16GB of RAM is unnecessary as well. you'd be better off saving the money and going for a 290.
Idk if there are any golden/black 290s though.
If there was an 8gb kit of that ram I'd go for it, the aesthetics and reliability of them out way the cost. Also a good price for a 2.4ghz kit
Also a 4670k isn't hard to overclock and just setting the multiplier higher is a significant improvement, a system builder can save that setting in the bios for him.
A 290 could be put in at the cost of less ram, slower ssd, cheaper case, less efficient psu. But the price to performance ratio of the 770 vs the 290 just doesn't make it seem viable to me.
I just compiled an all rounder computer where each component is of the highest quality for efficiency and reliability.
