In this link they test a confidencial i7 3770k vs 2700k and they say that it´s a total of 10% faster.
http://wccftech.com/i7-3770k-i7-2600k-benchmarks-surface-ivy-bridge-10-faster/
http://wccftech.com/intel-ivy-bridge-22nm-core-i7-3770k-es-benchmarks-unveiled/
ok people!
Let's start your bets?!![]()
i will go with the same 8% 12% difference as MAXIMIZE!
What I think is that it will be around 8 to 12 % faster then the SB and you will get higher oc due to lower wattage.
I am really interested in what the IB-E will do compared to the SB-E.
What is the performance difference between the SB and the SB-E?
Haha don't blame me if I'm wrong![]()
Hi guys,
I think that my first question starts make things a little more clear and logical to me (yes... I'm answering myself). The Intel´s tick tock policy makes me think that for those who already have a tick technology is not worth buying a tock technology. And for those that have a tock technolagy is not worth buying a tick technology! So i think it´s better to buy from tock to tock or tick to tick because, in my opinion, it.s a waste of money for so little performance difference!![]()
My cat had a TICK![]()
What is a P4?? TICK or TOCK???
I would say if you have Tick the don't mess with Tock unless Tock is way better then Tick but a move from Tick to Tick+ is beter then a move to Tock.
So in conclusion if you have Tick wait for Tick+ if you have Tock wait for Tock+ if you have AMD buy Intel![]()
witch P4 do you have?![]()
I got a 90nm 640 single core (retired)and a 65nm 945D dual core(current)
