PurE GaminG
hi everyone. need some help cant seem to find a retailer on googgle serch wher i could i could get the duplicolor spray-paints, in the uk.
also could you recommend some brands of spray paint which have personally used and can vouch for.
im going to spar my cosmos 2 case so ill be needing self etch primer, premium sand able primer, enamel paint, clear coat which all should be compatibly with each other.
plz guys ive been searching for weeks i even contacted dupilcoclour via email but had no luck with reply yet.
my whole project is on hold cause i cant paint the case.
also could you point me towards a store/ retailer where i can buy arcylic for cheap.
look forward to your reply's.
