RX 240 loop help
I have an OD in my rig too, i'm just to lazy to take it out:p
I only used it for installing win7 and drivers that were not online.
Drop he OD and fan controller. Go with a bay res and run fans on 7volt reducers. Solved:)
Thats probobly a good call . Although I'd like to have the ability to ramp up the rpm's on the fans if I wanted to . All in all your take is probobly the best solution ..
It would provide the cleanest build and besides you can run more rads in the future with fans on 7v as well further decreasing the temps and therefore running fans even slower.
Anytime! Great Choice btw. Now in the future adding blocks/rads will be easy and you know the pump will be able to keep up:)
Edit: Do not forget you will still need coolant or distilled water as the kit does not come with it. Figured i should point that out:p
