Running out of USB 2.0 headers
ahimoth
So I've used up all my USB 2.0 headers (all 2 of them) on my Maximus V Formula what could I do to add some more? Is something like this the only option? The reason I want another one is so I can plug my CPU cooler into a header. I have an Antec 920 Kuhler and it keeps bitching at me because as far as the computer is concerned I have no fucking cpu cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815201008
Thats your only choice only if you need to have your usb ports running at the maximum speed possible.
You could also use a powered usb hub if you plan to charge any devices that don't necessarily need data transfer, or just a normal usb hub, preferably usb 3.0 so if you have usb 2.0 devices, you will be able to max out the devices before maxing out the usb port.
