KING_OF_SAND
Sorry it was a bore... It wasn't intentional. Just wanted to know how you set up your cans with the card to make it sound good and not distorted.
Are you using the front IO? Reason being is that the front IO on the the Xonar cards sometimes does not work correctly.
Do you have the mini Molex plugged in? Common thing to forget Also read below
Sometimes the Mini Molex wiggles around and causes distortion, in which case just use some super glue and tightly glue that sucker in there. (this is what I did)
