Done some major updates to my rig since last I posted it in August of last year. (http://forum.overclock3d.net/showthread.php?t=56107)
I felt like I got some good honest feedback then and improved it significantly from my original build.( that was my first ever atempt and it shows.)
I have added a few things since then and with complete rebuild 2 days ago I thought it was time to share it again, and get some new feedback.
This is how it ended up last time. I did add in the rest of the hdd cases in the front but otherwise it was the same for quite some time.
Here is how it looked at the start of the rebuild, I got a second 780 and some new ram since last year. And added a fan to the hddcage.
All stripped down and ready for a dust off.
Everything fitted once again and only the hosing too go. Got a new PSU since the old one started acting up(reason for the rebuild in the first place) Decided too watercool the poseidon card aswell and added a 240mm rad.
End Result.
All in all I'm quite happy with the end result. Wanted too connect the 780s directly but was unable with the fittings I have, so I had to rework the loop a bit. Might also try to tidy up the 24pin and gpu power cables a bit, but not quite sure how to at this stage.
List of Specs.
CPU: intel i7 3770k
MB: MSI MPOWER z77
GPU: Asus gtx 780
GPU2: Asus RoG Poseidon gtx 780
Soundcard: Sound Blaster Z
Ram: 32GB (4x8GB) Vulcan 2133
PSU Corsair HX1000i
Storage: 1 corsair F120 120gb SSD, 1 Seagate baracuda Sata3 2TB, 1 external WB 2TB.
Loop hardware: 1 Acetal EK-Supremacy CPU block, 1 EK-Coolstream XTX RAD(360), 1 Phobya dc12-260 pump, 1 EK-RES x3 150, 1 EK-FC titan SE Acetal gpu block, 1 titan se backplate, 3 Spectre PWM 120mm fans, EK-Coolstream PE 240, Corsair Air Series AF120 Quiet edition LED Red and some Masterkleer 13/10 clear tubing.
Coolant: alphacool destiled water.
Case: White NZXT h630.
Please do share your thoughts of how I could improve for future builds etc.
End Result.
List of Specs.
CPU: intel i7 3770k
MB: MSI MPOWER z77
GPU: Asus gtx 780
PSU Corsair HX1000i
