Req. Skt.939 cooler - small
Rastalovich
Looking for 2x of these suckers, needs to be small - but would obviously like to be more efficient than a stock cooler. (got some stock coolers)
Preferably with air blowing across rather than down.. asking alot. If it has to blow down - so beit.
Height restriction is about.. well if u had a motherboard tray slid out of a pc, it`d have to slide in/out with it on. So no higher than the pci slots come I guess.
Oh yeah, you still after an aftermarket 939 hsf? Came across one of my old hsf's but not sure what socket it is :S.... it's the coolermaster aero V..
Doesn't turn up much on google. Plenty Aero 4's and 7's but not V's / 5's
Thinking it might be a socket A actually.
Edit: Ok so as it turns out the Aero V is actually an Aero 7... Makes sense :S
Pretty sure now though that it's a socket A so really just ignore me.
Like the much cheapness of these 3:
Arctic Cooling Freezer 64 Pro V2
Arctic Cooling Freezer 64 LP
NorthQ UFO 92mm
Bottom 2 have a low profile which will help I think (not wanting to come higher than the top of the pci-backplates) - not sure the 104/7mm of the top one will clear until I get home.
UFO blows down, but I may be ok with that. The x2 I want to take from 2ghz to probably 2.35/2.4. Not looking to goto 2.6/2.7.
Seen some others that look like the stock cooler, of which I already have a handfull.
I think the AC 64LP will be your best bet. It goes across like you want and seems like it is pretty short. Cant really tell from the pic but looks like a heatpipe in there too.
I checked out a few reviews on that, it looks like 2 stock coolers welded to a coiled heatpipe.
It doesn`t `look` like the air actually blows across/through it either. More like the effect u`d get if u did literally stick 2 stock coolers together.
Not that many good pictures about.
