replacing standard cables
tharionos
hi all ;
i recently build my pc but the cabling is still not at my wish
its mainly cause i keep seeing people with those sleek fabricish type cabling that just looks so awesome and somehow allows for better cable management ? ,
but ime worried about changing from the standard cables u get with the power supply
are they as safe as the standard ones ? , meaning as strong , reliable , life span
can u do much wrong with it
and is it really worth it ?
ime keen to know what u guys think about it and if u guys have any suggestions
company , brand wise
if want to look at my case as its now theirs a recent post in the post ur rig galary
i thank u all beforehand
kind regards
Hi there mate, yeah they are perfectly safe as normal psu cables.
They also improve aesthetics inside your rig, getting rid of the different coloured wires you see on many PSU cables.
It is worth in my opinion, as mentioned above, they look great and available in different colours you can be sure to get one that match the theme of your rig. The one's i recommend are the Bitfenix Alchemy extensions here's the link:
http://www.bitfenix.com/global/en/products/premium-modding/alchemy-cables
I've bought a few and i can say im glad i did, quality is superb, well braided
yeh indeed in the standard one's u get that diffrent coloured stuff and that was mostly why i was considering getting new ones also for the mentioning , its also cause the standard ones are really stiff !!!
very nice, i shall be buying a few when i get paid
trying to change my color scheme in my haf x from red to blue to mach the lights from my Kuhler H20 and my motherboard, only issue is the red pci brackets i have to put up with xD
