Renowned case modification stores
Saiohn
Hi, I'm going to be purchasing a 700d sometime soon but I have a few changes in mind that I'm not comfortable doing myself. I was wondering anyone on these forums knew of any stores that would do a good job.
Thanks.
Depends what you want / need done and where you are really.
I'm still not completely sure, I may even go for the 800d but I'm not too keen on the Hotswap as it's not something I'm going to make use of.
If I went for the 700d I'd definately want a window, not the Corsair sail but still something simple, just a sqaure shape but not shower the bottom compartment and I was wanting the plexi glass to be screwed onto the side panel over the window with Thumbscrews similar to the ones that come with Lian Li cases.
I do need to think about this a bit more
I was also thinking about having the bottom hard drive section removed but i've seen that the shelf above can dip a little when this is done so some sort of support would be needed.
I'll give it more thought and try find some pictures to show what I mean.
And I'm in Angus, Scotland.
Thanks.
Right you cant fix the window with thumb screws for one. and you cant really take the Corsairs apart without having lines every where as they are powder coated as one unit.
I really think you need to get the tools and do it for yourself. I wouldnt recomend anywhere in the UK any more.
Ok, thanks. Wasn't too sure if thumbscrews would work or not. I've just seen the LittleDevils case and I have to say that appeals to me more
so I guess I'll be saving awhile longer.
Thanks for the help.
