i was searching on google on how to reduce or eliminate lag since i used to have none but now i have loads and am running at 100Ping instead of what i used to have at 30ping
but anyway heres how>
I found this out in some Brothers in Arms forums a few weeks ago, I thought it might work for BF2 and it did. So I'm here to share it with those of you with framerate issues/overall lag.
It's very simple really. All you have to do is go to your EAGames/Battlefield 2 folder. Find the .exe file labeled "BF2". Rename this file to "BF2*whatever else you want*" where the stuff after BF2 is custom. You could even just put a 1, 2, highframerate, 1337, whatever. Doesn't matter. Just make it so it says something besides BF2.
After this is done, find your launch icon on your desktop (if you have one), go to Properties and adjust the target line to fit the icon you just renamed the standard "BF2" from. Hit apply, and you're done.
Your icon for BF2 may or may not change to a blank .exe symbol, and ASE may ask if you uninstalled, but rest assured everything is still where it should be.
"Well what does this do then?" you ask. Put simply, it turns BF2 from a resource and system hog to a regular, stable game. As far as I know it has something to do with Nvidia and ATI creating special "game profiles" that work with the game to "maximize performance" and run special stuff that's directly related to the game. Turns out you don't need any of that. After applying this change, both my copy of BiA and BF2 run at higher FPS's than ever, even with settings upped some. I was playing on a server in Denmark with 64 players with NO LAG!
Hope this helps those of you with framerate issues
information came from this website > http://forums.filefront.com/battlef...on/217620-new-technique-i-use-reduce-lag.html
im about to test it with MOHAA and see if it works
