Redline @ OC3D F@H Prop's & Bragging Thread..
Well the dual 80mm fans at 89 is the sweet spot I've found the loudest fans inside my storm sniper be are the fans I have in push pull on my H50 which is soon to be replaced once purolator shows up
im currently gettin 49 folding on my asus reference card @ 70% fan my msi is in the 80's cause thats sittin above that card with no space but its cooler than my asus card on its own but they will be split up soon when the new case gets here
What clocks?
In the nV control panel, set the Physx to CPU instead of GFX and the PPD will increase.
What clocks?
yeah thats what i told charlie to do the other day as i was having those problems myself but once i done that it sorted itself out might have to restart the client tho
It helped me massively with 2 cards. The first card was nearly 3K down until I changed that setting and restarted the Clients. They've both been nearly 12K each since.
What clocks on those charlie? Mine run at 11,476 @ 900/1800
I can get up to 930-940 Folding stable so far. I just unlocked my bios (full voltage range now, up to 1.213v
) so I'll be pushing for more.
