repton
Hey folks, here is the gallery thread for my personal rig. I've spent about a year putting her together with the most pricey parts being the last to go in just recently.
It's my first custom water loop having used mostly corsair H100's etc in the past.
So without further ado, here she is.
Rapture (Version 3)
We start with the delivery of water cooling parts
And here is how the rig looked before they went in
And here she is in her current state
Hardware Specifications:
Water Cooling
Rapture (Version 3)
- Corsair 800D
- Asus Maximus IV Extreme
- Intel i5 2500K @ 4.5GHz
- Twin 7970's crossfire
- 16GB Corsair Vengeance
- Twin Corsair Force 3 120GB SSD's
- 1TB Samsung SpinPoint F3
- Asus Xonar D2X
- Philips 273EL 27" 1080p Monitor
- Logitech z906
- Razer Blackwidow Ultimate
- R.A.T. 7
Water Cooling
- EK FC7970 Full Cover Waterblock for AMD/ATI HD 7970 Graphics Card : EN Nickel Acetal
- EK Supreme HF Easy Mount Universal CPU Waterblock : EN Nickel Acetal
- Koolance CU1020VS 360mm Triple Radiator
- Xilence Red Wing 120mm Quiet Fans
- Bitspower Z-Multi 150mm Water Tank Reservoir
- Mayhems X1 Premix Fluid for Water Cooling 1 Litre : BLOOD Red / UV Red
- Laing D5 (Alphacool VPP655-T12) Variable Speed 12V Pump
- Primochill PrimoFlex Pro LRT 3/8" ID - 1/2" OD (10-13mm) Tubing : UV Red
- Bitspower 1/4" Thread 45° Rotary Compression Fitting
- EK PSC 1/4" Thread Compression Fitting
[font=Verdana, sans-serif, FreeSans]I still have to do a few things, the remaining cables need sleeved. I may swap out the white sleeving for more subtle colour also. The rear cables behind the motherboard tray need a proper tidy up as I have basically just crammed them in with the side panel... I also plan to fit a Scythe Kaze master flat fan controller and upgrade the rear exhaust to a 140mm fan again in black and red.[/font]
[font=Verdana, sans-serif, FreeSans]Hope you like it, any comments or suggestions would be more than welcome
[/font]
[font=Verdana, sans-serif, FreeSans]Hope you like it, any comments or su[/font]
