Ram advice ryzen
MegaManDave
Hi All,
Can someone please advise on Mem for Ryzen 1800x. I'm looking to get the ROG CROSSHAIR VI HERO and I'm looking at get RAM speed of 3200hz = 32gb.
Any thoughts and recommendations?
As of now, I seriously doubt you'll get 32GB of RAM running at 3200. It seems the only people running speeds that high are using Samsung B-die chips, single sided, and only 2 8GB DIMMs. That's not to say it can't be done, but I haven't heard any success stories with 32GB, only 16GB. :(
I was lucky I was running 16GB of the Trident Z 3200 CAS 14 and it worked from day one. From what I have read, Asus is confident the May update is going to fix most of the memory problems.
If you get 32GB, it would probably be best to do it in 2 16GB sticks and not try to populate all the ram slots.
I recently ordered the 16GB of Trident Z 3200 CAS 14 kit. i can't wait to see how well it works with the Ryzen 7 1800X/Crosshair VI Hero that I've got.
I haven't put anything together yet as I'm waiting on ordering rads, pump/reservoir, tubing, & fittings. Lots of parts to buy, and I want to spread the purchases out.
4 sticks seems to be a problem for Ryzen atm but I know its something all motherboard brands are hassling AMD about
