Radiators
AxJaWz
I was just wondering what would be sufficient to cool an Intel core i5 760 quad core @ 3.8Ghz. I mean like what size and how many.
I have a HAF 932 Advanced btw.
I am prepared to do modding if needed.
Thanks!
if all ur doing is cpu at that oc a 240mm rad will be very adequate and ya can prolly get by with the thinner one. I'm contemplating a wc change and looking at a 240mm rad for my sniper case but looking at the 60mm variety as I wanna push it past my current 5.3GHz
Yeah but im using an A70 so im limited from higher overclocks. If i get watercooling I will be clocking it higher and I will probably get a new CPU next year anyway. How about a 240mm on top and a 140mm on the back?
that can be done or just get ya a 240mm 60mm thick with a good pump and block and fans you should be fine.
Yeah but I don't want a chunky rad on the top which sticks right down into the case with fans on it. I will get the measuring tape out and check it out. Thanks for the advice!
XSPC RS240 for a 30mm one or the XSPC RX240 for a 60mm one, both are good rads. The HardwareLabs Black Ice SR1 240 is also a really good rad, it's also designed to be used with low RPM fans so useful if you want to go for silence.
Id go witht eh RX. Its always Nice to have MORE headroom.
