SparkleDJackson
hello on my future build i was planning on including a fan controller (scythe kaze master pro or nzxt sentry lx) and i as wondering i would like to control both sets of fans (dual loop 6*120mm per rad) as united entities so on the first set of rad fans set to control 1 and fans on rad 2 to control 2 leaving the other 3-4 points open for use in other areas of the system. i covered electrical engineering like 4 years ago it my class and after i left i went straight into working in a bearings shop so the knowledge was not needed and therefore over the course of time powdered off to the park with its mates for a bottle of lucozade. so im thinking the power draw also maybe pe a factor so if there some sort of device that could be used to give the fan clusters all the juice they need but also combine the signal into one for the controller. i know the controller is not nescessary but i just think it would be pretty cool seeing the little display saying good job darin -15oC @ 15000rpm (exageration im not thick). any help you dudes can give would be uber appreciated i know this is about fans in the wc section but because its in relation to rads i thought maybe a few wc vets would have thought of this well before me. cheers
