Rad thickness
KTM_RULZ
I 've got a Corsair 800D and I 'm thinking of replacing the 360x40mm rad. I could install a 60mm thick rad in push-pull or a 80mm rad with a single set of fans. I'm thinking of the alphacool rads. Any ideas about the better choice? Thank you.
Push pull is really just for looks OR having the fans on silly slow. If you want silly slow you need a low FPI and not really give a shit about the lowest temps possible
Fans are important too. What will you be using? I have a Alphacool 360 Monsta myself with Gentle Typhoons. Couldn't be happier.
