clone38
Looking to put my cpu under a watercooling setup as these run a tad warmer that conroe`s.
Will a single 120 rad be ok to run just the cpu, or should i go for 2x120 one instead, my case is the Silverstone TJ09B,thinking of fitting the rad on the back 120 fan hole and the good thing about this case is it has two pre drilled holes on the back to take the hose`s into the case.
Can you recomend a cpu block,pump & hose for this setup.
Thanks for looking.
Thanks for looking.
