C Curtis Banned Nov 3, 2008 #1 Where would i buy Quick connect couplings from? Also, do they decrease flow rate? Any comments welcome!
K k4p84 New member Nov 3, 2008 #2 Hey Anything you put into a loop will decrease flow since they all impede flow to some degree. Here's a little reading : http://www.hardwarecanucks.com/forum/water-cooling/2703-flow-restriction-90-deg-fitting.html trying to keep your loop as uncluttered and short as possible is best. ED
C Curtis Banned Nov 3, 2008 #3 name='k4p84' said: Hey Anything you put into a loop will decrease flow since they all impede flow to some degree. Here's a little reading : http://www.hardwarecanucks.com/forum/water-cooling/2703-flow-restriction-90-deg-fitting.html trying to keep your loop as uncluttered and short as possible is best. ED Click to expand... Wow! Learn somthing new every day! Thanks for the reply,Much appreciated. (i won't be putting quick connector couplings in my new setup now)
M Marcus New member Nov 4, 2008 #4 The thread you linked to is a discussion about 90 degree elbows, not quick connect fittings. We've got some 10/8mm quick dis-connect fittings here though if you're still interested: http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=39_65&products_id=388
