FoldingZebra
Hi,
I am planning a build that will be doing soon and am getting stress out over the CPU cooler.
I am thinking I want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181088
Since Tom recommended this over the GTX.
Now here is my dilemma. That rad is 280mm so the fans are 140mm.
If I understand correctly, I should buy statc pressure fans to go on the rad. I love the look of these:
http://www.newegg.com/Product/Produ...992&cm_re=corsair_fans-_-35-181-027-_-Product
however they do not make those in 140mm. The 140mm SP fans are LED fans.
So here are me questions:
If I get the AIO that has the 240 rad so I can use these 120mm fans, will the colling still be good enough for overclocking the i5-6600k?
Has anyone used the LED fans and if so do they actually look good? I feel like LED fans would be a little too....... gaudy?
Any recommendations would be greatly appreciated.
Thank You!
Thank You!
