Hey guys,
I was wondering, my Gigabyte GTX 580 Super Over Clock came with OC Guru software, when you use this program, the 14 phase power LEDS (on the PCB) power on according to the situation, to save power etc.
I was told to stop using this and started using MSI Afterburner, the only thing with this is, the LEDS are all on, all the time, is this bad??
As soon as i open up OC Guru, it will only have a couple of LEDS on, and it will go up if you are playing games, and other things.
