Mgutierrez33
I am trying to map out a water cooling loop for my rig (it sits in a Graphite 600T), and having a hard time planning it all out.  Reason being: I ultimately want to have two reference-design GTX 670 GPU's and the processor being water-cooled, but I'm unsure of how much pump I would need for the entire loop, or for that matter how much radiator I would realistically need.  For the moment, I was looking at the dual bay res and pump from XSPC (X20 750), their Raystorm CPU block, XSPC Razor GPU block w/backplates, and the RS240 Radiator.  I know that that one rad will probably not cut the mustard for incorporating the CPU AND two GPU's (I intend on doing some overclocking), so the other options I was looking at were to mod the top of the case to incorporate a 360mm rad with an additional 120 at the rear, or leaving the top alone and doing a 200mm rad in the front.  Any recommendations based on personal experience/known good configurations?  Also, is the pump incorporated into the reservoir going to be enough for a loop like this?  If so, how would I tell/what are standard rules on pump sizes?
