Raptor1966
Motherboard: Asus P8Z68 Deluxe/Gen 3
CPU: Intel i7-2600 @3.5Ghz - slight overclock provided by Asus OC tool Turbo V
Windows 7 Power Setting: High Performance
i was running CPU-z recently and that it showed my CPU was only running at 1.6Ghz instead of 3.5Ghz.
i read elsewhere, if you disable C1E and Intel Speedstep (EIST) the cpu will run at it's full turbo boot speed all the time.
i disabled EIST and C1E and now CpU-z shows 4Ghz.
My question is, is it safe to have the CPU running at this speed all the time,
temp is 42 degrees and it is using the Intel stock cooler at 1370RPM
