AverageNinja
Average Penis Too
Hi there guys!
So a friend of mine has made the upgrade from the FX4100 with an HD7770 to the FX8320 with an HD7970. Now he has only put the GPU in, and he gets a lot lower FPS than another friend of mine who has an 3770k with an HD7950. Now I think this is about the FX4100 and they should put the FX8320 in and that would probably fix it. Though he is also thinking about sending the 8320 back and getting an 4770 (non k), and if he uses the 8320, he can't send it back.
So I told him that it probably is the 4100, with a possibility of it being the PSU (OCZ ModXStream 600w, I know :/), and I said I'd put it on OC3D just to be sure.
What do you guys think?
Thanks in advance!
Thanks in advance!
