Phil Stanbridge
Havent had a lot of time to test this setup yet, but what I have seen is simply stunning. It is without question the most powerful cpu I've had the pleasure to use, and it really is a pleasurable experience. Everything is smooth. My A64 setup was a tad disappointing in comparison, primarily because of the motherboard support, (and that out-performed my P4), but this rocks.
I'm going to volt mod my Asus SK8V to allow me 1.972 vcore (rather than 1.75)The Asus board tends to overvolt slightly also, so in reality this will give me 2v on the cpu. Even with the max at the moment, I am running @ 3ghz. It's not 100% stable, but its good enough for some benchmarks.
With a reasonable overclock on my 9800XT via the entry level waterchill setup, (472/398) I can get 24674 3dmarks. This is 1000 marks more than I could achieve with my best overclock on the gpu AND P4 cpu @ 4.2ghz! I still have lots of room for improvement on the gpu overclocks with this card. I might pelt it, or just add beter components - either way, I will break 25000 3dmarks with this setup.
Memory bandwidth is also a massive improvement over the single channel A64 setup - I get a shade over 6000 mb/s 1:1 with my ram at just 205mhz! Timings are excellent with my OCZ 3500 ECC 1GB - more to follow.
