Putting benchmarks on a flash drive
Greshapa
Hi, I'm trying to put benchmarks on a flash drive so i don't need to install them on several computers, Is there a way to do this? i tried installing 3D Mark 06 on one, and it did not work. Is there any that do work on a flash drive? thanks!
Edit: reason im posting here is because i cant find anything by searching, it just comes up as flash drive benchmarks
Won't work for FM benchmarks. They place settings in the registry. You should be able to install fine though on a single machine, it just won't work on other computers.
I do something similar, but hmmblah's correct.
What I do is merely have a Benchmark folder on a pendrive that has everything in it I may need to install. Then drag the thing to the dt and install where necessary.
Some things definitely need an install, many things don't.
Ah ok. Thanks for the replies, i guess i'll have to go with Rastalovich's method, 3d mark doesnt take long to install anyways so it shouldnt be a problem
