njallday
So in about 2 weeks I'm planning on ordering my water cooling setup, and I'm set on an XSPC RS360 and Raystorm, some Bitspower barbs, and Mayhem's Pastel White coolant, but I'm not quite sure about the pump/res setup.  I really don't like the look of a bay res, so that eliminates the XSPC X20 or anything like that.  I'm only planning on cooling my CPU, so I really don't need a D5 or anything close.  I was looking at the EK DCP 4.0 pump/tube res combo but I've heard it's a tad loud.  So, can anyone suggest a decent, quiet combo that should come out to be $75-100 (£50-65).
Now on to the whole tubing deal
.  I'm just wondering what a decent brand of tubing is, and would it be a good idea to go with 3/8" internal diameter tubing and 1/2" barbs?  Or should I just go with some compression fitting?
Thanks
Thanks
