http://www.extremetech.com/article2/0,1697,1932947,00.asp
404 ideas (in homage to "Mavs comment LOL
do not assume that the "SLI certified" label in the PSU box is a gurantee- most of the original PSU certifications were done on the 6 series of cards, and even though the 7 series are most power efficient, there`ll pulling more power overall. The X19 series is a complete unknown, so technically no guarantees can be given.
Its being suggested that X19 CF setups are given single-rail PSUs for better stability. The largest single-12V I can think of is the Tagan in combined mode, and that only gives 35A.
If the 7800GTX 512 can suck up 11A fully loaded BY ITSELF, an SLI setup needs 22A alone, that leaves 13A MAXIMUM for the CPU, HDDs, cold cathodes etc etc etc. This aint enough.
A multi-rail PSU can provide more amps over multiple 12V rails, but if the power draw on one rail is too large, the system OVP kicks in to prevent damage. There appears to be only one PSU (an FSP 700 GLN) can safely supply unbalanced 12V draws- the only limiting factor is the total ouput wattage.
Twin PSUs might be (read as "probably ARE") the way until PSU makers can sort this out.
Kenny
Kenny
