Good day everyone.
I am now on the hunt for a new power supply for a couple o' reasons, one being that ... recently I posted a thread relating to the fact that in the up coming future I will be upgrading to a HD 7950. I will overclocking the card also (Nothing super-crazy, gonna be using the cards 'come-with' cooler.)
Also my currently power supply is fairly aged now, I believe a solid 5-7 years have passed. It has developed more or less a constant buzz (un-noticable unless you have your head within 2 ft of the PSU)... However once every month or so it'll have it's "loud buzz" day.
So, with all the reasoning out of the way, here are my specs and requirements/preferences.
Main Consumption:
I5 760 @ 3.8GHz
HIS HD 5770 (practically stock) | -> Will eventually be a 7950.
Artic Freezer Pro 7 rv2
P7P55D-E LX Asus Mobo
[font=Verdana, sans-serif, FreeSans]8GB XMS3 Corsair @ 1600MHz (4x2)[/font]
[font=Verdana, sans-serif, FreeSans]Misc/Minor Consumption:[/font]
1x 200m+ NZXT Fan (don't remember specific dimension, but it's over 200)
2x 120m NZXT Fan
(Controlled via fan controller that comes w/ NZXT Phantom Enthu.)
1x Spinpoint F3 1TB HDD
1x DVD Rom whats-it.
Current PSU: Hiper 580w Type M (75% eff)
My Preferences / Req for New PSU:
Req - Enough to support a 7950 with the system above (I will not be upgrading for a LONG time, nor will I do CF)
Pref - Nothing drastically over what I really need. Sure a tad of headroom is a nice peace of mind, but like 300w over what I need is a bit far (in my opinion)
Pref - Mainly White (really not important, just would suit case)
Doesn't matter whether it's modular / semi mod / normal
Pref - If it's non-modular: I dont want a huge excess of cables, with the current setup, all that is spare is 1x 4pin.
Noise doesn't matter, so long as it doesn't sound like a hovercraft (or even lifts my computer off the floor with pure thrust
Wattage - ?
Pref/Budget: £90 At absolute tops
More than likely future additions:
1x 120m / 140m Case fan
1x 200m+ Case fan
1x 1-2 Metre LED strip
Sorry for the worlds longest PSU seeking thread ever, but I haven't really looked at PSU's or kept in the loop for the last 7 years-ish. So I'm not all up to date on the special gizmos and whats-its
Thanks in advance.
Main Consumption:
I5 760 @ 3.8GHz
2x 120m NZXT Fan
Wattage - ?
1x 200m+ Case fan
Thanks in advance.
