Quickie,
I know on the vapo's they spec a minimum height that the compressor has to be above the CPU, is there a similar spec for the Prommie's ? Im planning to put 2 CM 220 cases side by side with a custom front panel, one housing MachII & water stuff, other normal PC. Wondering if there is a minimum height that that compressor must be below the CPU ?
