paulstung
Cheers guys.
I woke up this morning and realised I've got a Monsta 420 just collecting dust, so I sat and had a think, I'm using an XSPC AX 360 up top and a 240 Monsta in the front, surely I'd be better putting a Monsta 420 in the front, and try and fit my ST30 360 up top, I thought I would just be able to squeeze the ST in as it is about 25mm shorter than the AX, but sadly even then it wouldn't work, it did fit but I couldn't use then front rads ports, and don't want the hassle of turning the 420 upside down so the ports are on the bottom, as the holes to mount don't quite match.
So I settled with the Hardware labs Black ice XFlow, up top, at least the rad space is about the same, well just a tad more than before, and with the XFlow rad it should make tubing a bit neater.
