paulstung
Time for yet another build, my M-ATX, didn't get very far as 2 Gryphon motherboards had problems, so here we are again.
Specs :
MSI Z97 Gaming 5
I5 4690k
8 GB 2666Mhz Tem Group Frost edition
XFX R9 290, in Crossfire
White Enthoo Luxe
Super Flower Leadex 1000w 80% Gold
2 corsair SP 120 LED fans up front
Storage
2 x Kingston 120gb HyperX SSD's
2 x Kingston 60gb SSDNOW 300V
1TB Seagate SSHD
Cooling :
XSPC AX 360
3 x Alpenfoh 120mm black and white wing Boost 2
XSPX Raystorm
Aquacomputer Aqualis ECO 150ml Reservoir with Nano Coating
Deluxe White Bitspower fittings
7/16 pro LRT tube
Mayhems Black X1 fluid
Just a relatively basic build with the odd mod here and there, like the MSI claws on the motherboard painted white, and a plate, to cover the back of the drive bays, there might be more, it depends on if I can be bothered at the moment, but if not they will probably follow in the weeks to come, one thing I want to do is to add a stealth motherboard try cover, we'll see I might just get it done when I sort the bay cover plate.
What looks like a smeared edge is masking tape gunk.
I'm off to finish painting the rads, for some reason the paint keeps flaking, even after 3 primer coats, so I bought a thicker paint on primer, and useds a roller so it needs a good sanding before the first top coat.
Specs :
MSI Z97 Gaming 5
I5 4690k
White Enthoo Luxe
Storage
1TB Seagate SSHD
Cooling :
XSPC AX 360
XSPX Raystorm
7/16 pro LRT tube
