Nope this is my first build I have done some minor mods before but nothing major and worth mention.
Sorry but I don´t want to tell all the measurements until maybe after the project ends, hope that you understand.
But i can give you some advise, look at other chassis big tower and midi tower depending on how big you want it to be, and the take the measurements on the components, and then figure out how you will be able to fit everything in there
one big thing to think of is if you going to watercool everything or if you will use air then you have to think different but that you maybe already know
The thickness of the aluminum is up to you aswell, I have gone with 2mm and 5mm, but this also depends on how you will put everything togetherI know that some modders like to use 1mm and max 2mm but then it might be hard to get the design great, then its lots of bending of the metal to get all panels to fit together.
Hope you understand and that my tips will help you, if you got more questions just ask themand I will try to help you
/Bl00m
Thanks mate. Ive already taken most measurements for my design was just looking for more advice. And when you build can u please say what tools you used. Thanks again.
