Project Shelfie
That is awesome! :cool: Bravo dude, I really do admire the originality and uniqueness of what comes through these forums.
You could try using RealTemp version 3.70.
I have found it gives quite a good temp reading and is often consistant with HW Monitor. It also allows you to see GPU temps of each card.
What program did you use to get the cpu temperatures? AMD's overclocking software gives a much more accurate temperature.
Hi, I used Core Temp, Hard Ware Moniter and Easy Tune, I tried your suggestion as didnt think of using that program, alas though for the overclocking part of CCC isnt as adjustable for APUs as it is for GPUs and does not have the temperature monitering part of the software.
But will try and look at a way of downloading the full version if i can
Pete
