Project: Nuclear Fission
I will try to mount the CoolerMaster front 5.25" fan controller inside the system under the 5.25" bay bracket which will clean up the front of the case. I am still waiting on the sleeving, but I will be getting something special soon. You will have to wait and see (hint: I now work as a packaging/logo/advertisement designer for a new company)
I bought some sleeved extensions so I will be using them in the system until my sleeving arrives and I finish sleeving the cables.
I need more radiators in this build due to the 480's
So, either a Dual 180 Magicool radiator = $90 or Triple 180 Magicool radiator = $110?
I have had an idea. Not sure how it would look, guessing pretty damn sexy, but here it is; Cut out thin UV acrylic pieces and place them in-between the fins on the RAM-sinks. Possibly either blue or green UV acrylic.
It looks pretty nice, although I'm a fan of big colour (see mine :D ) I have to say with a recent build i just did that a white led strip really brings out the colour in all the components nicely - i won't have any coloured ones in my next build :p
Thanks guys. I still need to find time to heatshinkless sleeve the cables with paracord. I have 300ft total of black, green, and blue.
This is my 24/7 overclock. 4.8GHz at very 'low' voltages. Idles at around 1.27-1.34v then at load it gets up to around 1.37v. Very happy with this chip :)
