Dicehunter
Resident Newb
So not really much of a project but the goal is to neaten up wires etc... so far I've neatened things up with cable wraps, Still a few fan wires to wrap, A few cable combs, A mid plate for the Corsair 540 and in the days to come I'll be sanding, Gluing then painting the 3D printed Asus mobo 24pin covers, Both short and long versions to see which looks better, It helps cover the 24 pin and makes it look really stealthy.
I'll also be doing a little mod to mount the GPU sideways, This way the snazzy looking underneath can actually be seen, I'll be cutting into the actual PCI slots on the case for this mod.
Progress so far -
Progress so far -
