Project: Moist Mog
JN
After a few months of boredom after spraying and water cooling my stacker, i've decided its time for a new project :D
Coolermaster Wavemaster (Silver)
* Silver annodisation removed, aluminium sanded to 2000 grit, polished to mirror finish.
* Rear 80mm fan bored out to 92mm
* Hole cut in bottom of case for phase change
* 2x120mm holes cut in top of case for dual radiator
* Drives sprayed chrome to match case
* PSU sprayed chrome to match case
Cooling
Chipset / Graphics cards
* Dual Thermochill rad
* YS-Tec 125cfm fans
* UV 1/2" Tubing
* Danger Den D5 Pump
* Dual floppy reservoir
CPU
Mach I or II with Lian-Li kit (treated same as case)
Pictures of parts as they arrive :D
Wirelessly posted (Nextel BB7520: BlackBerry7520/4.0.2 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Feckin sweet bro! Phase changers unite!
Can't wait for some piccies :)
**Update**
* Case Ordered and being sent to KustomPC's for hole cutting.
* Extra fans ordered
* Dual fan grill ordered
* 1/2" ID UV tubing ordered :)
Any updates mate... have Kustom started/ finished your case yet, and how's the annodisation removal going (did Mr Muscle work)?
Sorry about the lack of updates, but its mainly because i'm pi**ed off with how things are hoing at the moment :mad:
Case arrived at kustompcs, but they are unable to cut the holes where i want them (even tho i've seen it done on other rigs with same specs) - i think they are just being conservative.
So now, the case is going back for a refund, and i'm looking into a silverstone case, and maybe changing the project slightly.
I did try Mr Muscle on the annodising of my stacker, but it just seemed to tarnish it, making it harder to remove rather than easier :(
Oh man that sux, it's a pity the bloody great pond that seperates us is soooo big or I'd have a crack at it myself for ya. I have all the equipment I'd need at my disposal here.
With regards to the Mr Muscle, I reckon it doesn't have enough caustic soda content to remove the anodising. I'll have scout around for another UK based product that'll do the job
Yeah cheers mate. If all else fails i might get a painted aluminium case, and strip the paint off (i doubt they would annodize a painted case?)
Get urself a nice roomy u2-ufo mate! That solves all of ur problems (all but the fact it would be a bitch to fly a u2 over the atlantic, lol)
Yep just a bit ;) and the fact that i'm trying to reclaim some livingroom space ;)
you can get wall cleaning soaps that contain quite alot of caustic soda. have you condiered a mild abrasive like T-Cut?
Yeah i've tried T-Cut and other cutting polish. You have to take to annodizing with sand paper to really appreciate how much protection it adds to aluminium.
Anodizing is pretty much indestructable!
Wtf reclaim space??? U shoukd be stacking computers in every last square inch! :D
What case are u thinking about going with now?
